Contents
Index
Search
Introduction
IMPORTANT TIP TO IMPROVE PERFORMANCE FOR AntiVirus Users
Some Default Alias Commands
Basic Installation and Usage
Installation
Basic Usage
Creating Your First Alias
Explicit Directory Searching
Searching in Specific Directories
Advanced Directory Searching
Non-specific Directory Searching
Directory Searching Tricks
Configuration
Main Options
Heuristic Scoring
Pattern Scoring
Search Folders
Launch History
Aliases
Advanced Use
Results Window Operations
Tip: Use Batch Files and Scripts
Keyword Modifiers
Non-contiguous Search Words
Search Edit History
Negate Search Words
Hotkey and Shortcut Summary
Using Alias Action Keywords
Restricted Search to Files or Folders
Using Clipboard Tricks
Alias Listing/Launching Tricks
The noresults alias
Using Alias pattern of * to match all searches
Special/Virtual Launch Strings/Commands
Using a regular expression alias for complex searches
Regex Alias Filter Patterns
Special Search Phrases
Special Search Modifier Keywords
Tips and Tricks
Variable Replacements, Virtual Folder Names, Env Paths
Alias Files
Commandline Options
Html View Mode
User Variables - Advanced Use
Special Predefined Variables
Passing commandline parameters/arguments
Using sendkeys to simulate key presses
Using CapsLock and other keys to trigger FARR
Plugin System
Introduction
Plugin API/SDK
Commands Callable by Plugins
Values Getable by Plugins
Callbacks made by FARR to Plugin
Available Plugins and Alias Packs
Plugins and User Variables
Adding Custom Menu/Button Items
Troubleshooting
Can't Launch Programs/Documents
Related Programs
Version History and To Do List
